Please what could be the problem and how do I fix it?
Fri Oct 12 2018
My C arm suddenly can't go up and down on pressing the height adjustment buttons
Fri Oct 12 2018Reply from Larry Price
There is a safty switch connected to the cover that can cause this. If that's not it then either the motor has gone bad or the shaft may just be too dirty and dry to slide. Do you hear anything when you push the button?
Larry Price
Sun Oct 14 2018Reply from Hengo
Wed May 22 2019Reply from Araldite
It may be the emergency button circuit that is disconnected, I forgot to connect it and it did not go up or down. After the connection it returned to normal operation.
