How to properly install a battery pack into the burdick atria 3000
Mon Oct 22 2018
Battery
Mon Oct 22 2018Reply from TSS Jim
Open the paper tray by removing the paper door. Remove the paper. Just inside the bottom of the paper drawer is a metal plate. Probably held in place by 2 strips of tape. Remove the tape, place a finger in the hole in the metal plate, lift up a little and the plate will slide upwards or downwards and then lift all the way up. The wires seen are on a connector. The wires can be pulled down to disconnect the battery from the socket.
