I have the service manual on this unit, but it does not show the circuit level diagram of the CPU and Power Boards. I am trying to figure out why the defrost is stuck on. Has anyone run into this? Thermo told me that it was not a common complaint. The machine thinks all is OK and it has commanded defrost off, but you can reach in and touch the area where the defrost mat is and it will be hot. Also with the mat connected the machine will not cool down below -15C (can't get rid of heat) I have unplugged the mat as the customer only uses the machine once a week so there is not a big issue with frost, but need to try to figure out who is the culprit here.
Fri Nov 16 2018
HM-550 Evaporator defrost steady on
Fri Nov 16 2018Reply from Garrobo
