Agfa CR 30-X doesn't recognize cassette format
https://www.manualslib.com/manual/1207761/Agfa-Cr-30-X.html?page=162#manual
Try replacing the Cassette Edge Sensor and make sure the the transport rollers are in good condition.
Jimmydogz34@gmail.com
Check that the fix mechanism is not cracked, if so you would have to replace the fixation unit completely or make this piece in a lathe
Ok, I will check the fix mechanism for crack.
So, I have crack, even on several places. Are you 100% sure, that the problem is from this crack on fix mechanism ? Can I solder or stick it with some glue or tin for alloys ???
You might try looking at the notches on the right side of cassette. Sometimes when they are worn out, the fixation band will not recognize the size. Had this happen at a couple locations and swapping out with a new cassette caused the issue to stop. Ordered new cassettes and never heard back from them.
