How to clear error 38
Thu Jan 17 2019
Error 38
Thu Jan 17 2019Reply from krkenney88
Hi rob,
When the alarm message displays, press the MENU key and then select ALARM INFORMATION in order to gather more data as to what is causing the error. If you can report back here, I should be able to offer further assistance.
Although I'm not familiar with all of the error codes on this system, code 38 may refer to a specific rotor, which may not be secured. I would check your rotors in addition to triaging the alarm information.
Koby Kenney
MedWrench Guru
Wed Jan 30 2019Reply from Lindsay Orr
The service manual is available here . Also, Ozark Biomedical may be able to help you.
Sincerely,
Lindsay Orr
Data Entry Coordinator
