Fri Feb 08 2019
Will not draw a vacuum on the chamber
Initial issue "Too long to evacuate". Water pressure 35PSI, replaced all components kits , seats, coils, injector, heat exchanger, check valves. verified pressure transducer is working with in specs. Steris is confused can't find the problem. WTF, any ideas?
Mon Feb 11 2019Reply from Kara Crissman
Dear Matt D.,
We came across your post about the AMSCO 400 Series Small Steam Sterilizer. We have a dedicated Service Support team who can help. Please provide us with your preferred method of contact or call 1-800-333-8828 for assistance.
Sincerely,
STERIS Corporation
Wed May 15 2019Reply from Chris35
Assuming you replaced all check valves, including the 2 on the heat exchanger and the 1/4" NPT swing check coming from the exhaust manifold, rebuilt all the valves and checks in the 3 manifolds, replaced the ejector, and rebuilt both traps, (mainly the jacket trap, including the seat) and verified your transducer, calibration, and control, then my next check would be the door gasket leaking steam into the chamber during vac. Bad gasket, dirty channel, or both.
What are your vacuum levels and what is the temp reading when it bottoms out? Does a lot of steam come from the chamber after opening the door upon failure?
Oh, you did check the chamber drain strainer inside the chamber, right?
Mon May 20 2019Reply from Cbet_Matt
Cbet_Matt
Sorry for not letting you guys know. This items is repaired. S1 was intermittantly sealing. Coil was good but the diaphragm assembly was bad.
Matt
Mon Feb 17 2025Reply from Chris-CBET
Chris-CBET
your water pressure is too low btw. should be at least 40 dynamic
