Tue Feb 12 2019
compressor and fixation
The 18x24 and 24x30 compression plates : quality control tests not pass; with simetrical and assimetrical loads distance of compressor plate corners to bucky exceeds tolerance 5mm sim and 15mm assim. I need to replace rollers of comp plate and fixed support of RT. Can you help ? manuelmaia@equinomed.pt +351 93 848 8241
   RE: Mammography Report Post
