error code
THe BIOS is corrupted. You may need a new SRAM card, if you can get it to boot fully, pull the card with the system running, check the bios battery voltage, should be greater than 3.0 VDC, if lower replace the battery and reinsert before shutting the system down. Removing the battery will lose all bios settings, however if you replace it and reinsert before shutting down the files will reload onto the SRAM. The Technique Processor PCB is responsible for initializing and controlling the 9600 C-Arm. Application software for the system resides on the SRAM card located in the on-board solid state disk drive U13.
Started Execution of Option ROM Code
1. Bad Option PROM 2. Bad Communication PCB 3. AT Motherboard not functioning
