What does it mean?
Fri Feb 22 2019
F 38 Error Code
Fri Feb 22 2019Reply from dbohrer
F-38 is indicative of a failure of one of the tube misload sensors. If you hold down the clear total volume button and the #2 button while turning the device on (continue to hold down clear total volum and #2) it will allow you to see readings from all 4 tube misload sensor. If you open the door and put pressure on any of those sensors and the numbers don't move, it's likely that the particular sensor is bad.
Hope this helps!
