I would like to ask, is when we take off board and then install the rtm again would have to set the IP address reset?
Sun Feb 24 2019
RTM Not connect
Fri Mar 01 2019Reply from Lindsay Orr
Fri Mar 01 2019Reply from RichardsonHealthcare
Hi, Sukwono! I spoke with one of our QA engineers here at IMES and we'd love to help. Are you removing then reinserting the original RTM board? If so, you wouldn't have to change any IP address settings. Even if it's a new board, you shouldn't have to change any IP address settings unless you're trying to run the independent MHR board diagnostic test. If you need further assistance, give us a call at (704) 239-3597 option 3! Have a great day.
Wed Mar 06 2019Reply from Carlos912
