OCP error
Best regards,
The MedWrench Team
Bee jay
S2000 is a different issue
What exactly your problem with it to be able to help you
Hi kaylee
I have no problem in sharing my data with the team
There is another discussion with the same problem and i answered it till the main componant that replacing it solve the problem
I have a NX3 power supply, I turn the machine on and at the same time the power supply is defective, the OCP led lights up, just clicks and nothing more. Does anyone know how to make the font stressed?
Sir, I have the same problem with a OCP error in a SIEMENS ACUSON X300 ultrasound unit. The scenario is, the unit powers down 5 to 10 seconds after a successful boot up sequence. Can you enlighten me as to what could be the component or PCB assembly that causes this problem? Thank you in advance for your prompt answers..
