serial out of data
Hello, my name is Joe Sheldon I am with Integrity Biomedical Services we specialize in Spacelabs medical equipment. The feature that you are referencing is called Patient Data Logger Option R on the 91369 Ultraview monitor. The monitor must be attached to a computer through a serial NULL MODEM CABLE and hyper terminal setup on the PC. This will allow monitoring of all vital signs being fed into the monitor. If tech support is needed, we here @ Integrity provide FREE TECH SUPPORT. Please call us toll free @ 877-789-9903 we are located @ 800 North 16th Street Broken Arrow, Oklahoma 74012
Please give Jeff Arneson a call at 800-880-7231.
Thank you,
Tracy Neilson
Southwestern Biomedical
Good morning this is Joe Sheldon with Integrity Biomedical Services. The first question I need answered is where are you trying to have this SPO2 readout viewed or sent to? It appears that you are wanting an instantaneous printout of the SPO2 waveform if this is correct you would need to utilize the record function of the monitor. Does the monitor have a recorder built in? If not set the unit to record to network. If any help is needed to set this up, please give me a call @ 877-789-9903 8am-5pm Monday through Friday central standard time.
HI Joe Sheldon,
The monitor have a recorder.. enabled the recording option and try to continuous record.. But i'm facing one isssue like "Unable to record the requested channel".
(facing an issue to insert the image of monitor to this reply.. )
TO CONFIGURE RECORDER - Select monitor setup button next at the bottom of the screen select recorder config then select recording destination also at the bottom of the screen make sure both alarm recordings and other recordings are set to this monitor. This should allow the recorder to function. If you need any further assistance I am available @ 877-789-9903 8am-5pm Monday through Friday central standard time.
Joseph Sheldon – Integrity Biomedical Services LLC.
