Hi Everyone
There is a way of removing the , Replace Battery Message. This is by adding a Resistor in Parallel on the main mother Board. Unfortunately I've lost my notes over the years and I'm hoping that some one out there received the same ,"Repair Signal" all those years ago from NK Japan. Can anyone remember this fix, the value of the Resistor and Placement on Main Board?
Regards
Marc
Mon Mar 25 2019
Mon Mar 25 2019Reply from Marc Paul
This is for an Older Defib, Nihon Kohden TEC 7511, that uses the Lead Acid Battery NK X041B
Fri Mar 29 2019Reply from MedWrenchManager
Mon Mar 23 2020Reply from bratok1
Countermeasure
When this problem occurs, replace the R0831 resistor (10 Ω) on the UR-0120 Motherboard with a 49.9 Ω
resistor.
49.9 Ω Resistor:
Description Code No
RN41C2DT3 49.9 ohm F 1/5W 158731
