troubleshooting
Error code 566 has to do with excessive resets before UIF runs. The service manual is located here.
Turn on the N-595 by pressing the ON/STANDBY button. 2. Wait for monitor power-on self-test to complete. 3. Simultaneously press and hold the LIGHT softkey and the CONTRAST button until the service softkeys are displayed.
Note: The service function is only accessible from the main menu display. The menu bar will change to the headings listed below. Note: If the above step is performed with a pulse oximetry cable connected, only the PARAM and EXIT softkeys appear on the screen. The following list can be used as a quick reference showing how to reach different softkey functions. Items reached through the PARAM softkey can be accessed during normal operation. Functions provided by the PRINT and NEXT softkeys cannot be accessed when a pulse oximetry cable is connected to the instrument. Each of the various functions is described in the text that follows. PARAM (Service Menu) - RESET - - RESET DEFAULTS? - - - YES (resets parameters to factory defaults, sounds three tones to indicate that defaults have reset) - - - NO (back to Service menu) - SAVE - - SAVE DEFAULTS? - - - YES (saves parameters as default settings, sounds three tones to indicate that defaults have been saved) - - - NO (back to Service menu) - SENSOR (enables/disables sensor trend writing on rewritable sensors) - - BACK (back to Service menu)
