Hard disk
Check your bios battery on the SBC should be greater than 3VDC. Could be your hard drive as well.
From the service manual. Generator object tasks initialize. If boot-up fails on this arrow, check communications between Workstation and C-Arm. Check the ARCNet. Verify that Workstation completely boots.
Hello!. Stopped boot on 5 arrows means communication problems. Check the main cable between WS and C-arm
GD
Sounds like you you have pins on the lemo connector that are pulled back. Take the dog house off and check the pins on the back of the lemo connector. You might be able to get lucky and pull out the tabs on the pin. If not just replace the lemo connector.
Thanks for your time. I already checked the lemo connector and its good. Really the workstation can't boot. I connected a vga monitor to see whats the error in booting and I found that there is no hard disk drive to complete booting.
