Hard Reset
RE: Pulse Oximeter Report Post
That word you're using "fixed" I dont think you know what it actually means. By power cycling the u it you have temporarily cleared the issue. At no point are you addressing the cause of the issue. If you addressed the cause of the issue and solved it, that would be fixing the problem. Have you contacted masimo technical support and spoken to someone other than the tier 1 noob?
Thanks a million Chris.
I was confused for a while by a common issue in Radical_7 touch screen model.
At least 50 percent of them have same problem.
After about 25 second after power on, the screen will be dark with an audible alarm.
In my opinion it is a software bug!
I have done Mrs.Chris suggestion and it works.
Masimo just asked us to return units to replace with new ones without any technical instruction unfortunately!
I also have some issues with 2 Radical 7 devices - after some minutes of displaying the pulse, the "speaker fault" appears on screen and the device has an audible alarm. Do you have any suggestion on this?
Bestr regards,
