Treadmill communication is disconnected
RE: Treadmill Report Post
I have a TM55 connected to a Q-Stress system and , even in the manual calibration mode, elevation works fine but, when 'start' is selected, the motor moves the belt about 3 inches and I get an error on the display "motor overheated" followed by "treadmill communication" error. It is no longer supported by the Mfg. The service manual for the treadmill doesn't help much, suggesting I replace the VSD (variable speed drive= the entire card cage with frame). I ohmed the motor windings and they are equal at 1.8 ohms; the pcb connections for the motor measure about 570Kohms; the fuses are good, the led's light when they are supposed to (except #1 which, following start, illuminates briefly then goes out). Any ideas??
