Bed was in up position with pstient in it. Made a weird sound then quit working on everything. No lights, no side power /either side , no lockout controls or relock in working ..nothing at all will work. Bed is stuck in a hogh position now close to the ceiling and cant be used ..help please. Cant find a single tech to work on the bed because we didnt buy it from them and many more excuses. Did change a small fuse iut noticed it was blown. . Clueless and manual i ordered hasent helped at all.
Tue May 07 2019
Bed stopped cold turkey -working
Tue May 07 2019Reply from Kenneth V
does the bed "brake not set" alarm sound when bed is plugged into wall power? look for led lights at top left of side rail interface board, if not you might try replacing the power cord and work your way out from there.
Mon May 13 2019Reply from belvedere
Like Kenneth said, just work your way through and see where you've lost power. Hopefully the manual you have includes schematics, which make it fairly straightforward.
