6201 Latch roller
RE: Infusion Pump Report Post
AIV is a no, IMED is a no, waiting on the others to check for us.
This supprises me as this is a common wear part to replace.
Thanks for the response!!
It does not come seperate. Its in an assembly SO047945. The components of the roller assy are pressed in and the part number SO48455 is just reference to that for the parts diagram purpose. Hope that helps. Its a low failure item so it might be hard to find one. You can search for a 6301 or even a 6200 as they all have the same door assy I believe.. 6301 for sure does.
Hope that helps a little!
mrstan
I just checkedc and the assembly is available here (or so the site reports on its parts search).. LOL
https://www.sepems.com/parts-2/baxter-6201-parts/
Its like the 12th item down as I am looking at the page... Hope this helps...
mrstan
mrstan.
Found out that flat spots on latch roller was the cause of occlusion sensor F codes; you can verify and or perform calibration, only to have F code return when the door latch roller rotates back to the flat spot.This has happened so often after reapirs that we have found a manufacturer to produce this part for us.
Those interested in quantities in lots of 25; please post your email address and we will contact you.
Those interested in quantities in lots of 25; please post your email address and we will contact you. Let me know $$$$$
