Change Language from Japan to English for CR Fujifilm-FCR PRIMA Software
Thank you for the comment, but is there any other way? since the product came without installation disk.
Hi all friends i can help u all cr printers kodak konica fuji serives manual at equipments.plus@gmail.com
The language of the software is set to Japanese. To change the language, you need to uninstall the software and then install it again. Once you have installed the software, you can change the language by going to the Settings menu and selecting Language.
You can also change the language from the main menu of the software.
You can easily change the language from Fujifilm CR software CORNACORE Station.
Step 1: Find the configuration, click the user setting=> language
Step 2: Highlight the desired option and press Menu/OK.
