How do I adjust the two field of views to overlap? Currently the right eye FOV is slightly high and to the right.
Fri Jun 14 2019
Field of View
Mon Jun 17 2019Reply from MedWrenchManager
Mon Jun 17 2019Reply from Phil Herren
Wed Jun 19 2019Reply from MedWrench Mandy
I would recommend contacting Leica.
email me: mandy@medwrench.com
Connect with MedWrench:
Fri Jul 12 2019Reply from Microscope Man
Sounds like a prism mis-alignment. Depending upon how brave you are, you can go in and try to tweak the prism but you better know what you are doing. Without the proper tools and knowledge, you can make it much worse.
