Leakage tests on the bellows and lung test were successful and normal cycling.
However, the low pressure alarm is always active.
It should be noted that the oxygen bullet has a normal pressure, it is not low.
First of all, Thanks.
Fri Jun 21 2019
Low pressure problem in Anesthesia machine ACM 606
Sat Jun 22 2019Reply from T.J
1. Check alarm setting, 2. Check pressure sensor if it is getting full pressure delivered. 3. Replace alaram pressure sensor/transducer. Hope it works.
