Service Manual
email me: mandy@medwrench.com
Connect with MedWrench:
Hi Allan,
good afternoon.
I found some materials for you, including the service manual:
this is the Fabius GS (not exactly the same)
http://www.heartlandmedical.com/wp-content/uploads/Fabius-GS-User-Manual.pdf
Then this is the service manual for the Fabius
https://www.scribd.com/document/271834821/Drager-Fabius-Service-manual-pdf
Depending upon what is wrong with the machine, the service manuals should help out to fix most of the little things with these gas machines.
However, is something is broken that is too costly to replace, then you may need to look at putting a request into the buying agent at your hospital to pick up a used gas machine.
We recently picked one up from the med device auctions over at Mazree.com. That is what brought me here to this post in the first place. grin.
Hope that helps you figure out the solution to your problem.
Greetings everyone, I have a few Drager Fabius GS Premium and I need to reprogramming the next PM Schedule in the service menu, but the unit don't let me change the next the schedule after 12/31/2020. I will appreciate any sugestions.
You won't be able to get past year 2020 till you install the new software. Down load software from service connect.
