Error 4
Hi CML,
This page shows the specs on the laser. (at the bottom)
https://www.rockbottomlasers.com/products/2009-candela-syneron-quadralase-co2
Depending upon what the problem is with the machine, those specs may help.
This site has the brochure. Not exactly a users manual.
http://www.medicom.cz/UserFiles/File/Lekarske/Candela%20QL.pdf
This site shows several companies that use these QuadraLase lasers. So, you could contact them to get a service manual to lookup code Error 4
https://pdfs.semanticscholar.org/e1c5/6cacd47a729c79ac377e8b729f6c4aee7afd.pdf
I wish I could help more to solve your problem faster. Not exactly a panacea. grin.
Depending upon what is wrong with the laser, you could fix it yourself, or you may need another laser. The best source that our small hospital has found for used inexpensive equipment is Mazree.com auctions. They help to save the purchasing department's budget.
