BVI 3000 Calibration Procedure
RE: Bladder Scanner Report Post
Hi DMartalock,
The manuals are ready to go on MedWrench for you.
here: https://www.medwrench.com/documents/view/6998/verathon-bvi-3000-operations-maintenance-manual
and here:https://www.medwrench.com/documents/view/1519/verathon-bvi-3000-operator-s-manual
AS for calibration and settings. They are at the front few pages of the operations manual. But, the error codes, if you need them are on page 25 and 29. From this message, I couldn't tell if you needed to just "setup" the machine properly, or if there was a problem with it and you needed the error codes.
As for Verathon's servicing the unit; if the unit is broke somehow, then there are always 4 options:
1. Contact a repairman that specializes in medical equipment.
2. try to fix it yourself, by buying the parts and fixing the machine.
3. buy a used bladder scanner- This option is sort of new in the world of medical equipment. It was only 5-6 years ago when this became a serious option. The equipment can usually be purchased from one of the many used medical equipment suppliers online. However, there are only a few places to put the sale into an auction format to pick up some really good deals. One is Mazree at https://www.mazree.com/smart-auctions
4. the last option is to buy new through the normal supplier. This is last because it is the most expensive. But doable, depending upon your hospital purchasing budget.
You can contact Verathon as well.
email me: mandy@medwrench.com
Connect with MedWrench:
I can't find a calibration procedure nd my unit is just a bit out of range on my phatom. Any suggestions?
@dmartalock : you need the Master key to access some ''special'' menus. You have to order it + you need the string phantom . You don't have to send the equipement to a repair shop.
Here is the part no. : 0810-0110
Good luck !
Hello Vernipoupou@ dmartalock Do you have a part number or maby a picture of the string phantom? and perhaps the actual calibration procedure? I have the key and the calibration tank. not sure if I need anything additional to this.
Hopefully okay to high-jack this thread for a quick question.
What does the imaging head sound like in normal operation. Mine whirs, then tap-tap-tap, then whir beep, whir beep...12 times. The rattle seems odd to me, but then I have never heard one before. I assume it homes then runs the 12 image sweeps. Thanks in advance for any knowledge.
