I have a new power supply and new socket and new lamp. I have 6 volts at the lamp socket and it will not light it. I have tried 3 lamps also. Any ideas?
Mon Aug 12 2019
Lamp not coming on
Tue Aug 13 2019Reply from MedWrench Mandy
JM70 - I would contact Unico directly.
email me: mandy@medwrench.com
Connect with MedWrench:
Tue Aug 13 2019Reply from amorales
Have you clean the contact of the lamp????? Some time the problem are the contact are dirty or they are not a good contact and it not the lamp socket.
Tue Aug 13 2019Reply from JM70
Yes checked all contacts. It's crazy. The pot works fine also. Goes from 1.9 volts to 5.98 volts
Mon Aug 19 2019Reply from Microscope Man
What is recommended wattage for this equipment. Also, what manufacturer, model number? If all your parts are new, I would go back to company you purchased from and have them replace the parts. If it is the Unico 380, that is supposed to be an LED lamp and should last you forever. (At least 50K hours.)
Microscope Man.
