Please help, Problem about transmiting data from Mindray BC-3000 Plus to Host computer. I Configure Mindray BC 3000 Plus for Data Transmit through Host Computer. I am Receiving Strange Data Through Serial Port. Configure parametter on Mindray BC 3000 Plus : Using Serial Port 2, Baud rate (9600), Data bit (7), Stop bit (1), Parity (None), Handshake (Off). Is there any solution ? Thanks you so much. Data received : [STX]AAAI10P1900000000000200820201914110068002100120035304176520431183041810160424136437015809016314205080000000000001011000001004006725502920701823600000000000000000000000000000000000000000000000000000010060120190280400560781051281601872122362492 ... continue ... [SUB]
Thu Aug 22 2019
Problem about transmiting data from Mindray BC-3000 Plus to Host Computer
Wed Sep 11 2019Reply from phienit
i'm Configure Mindray BC 3000 Plus for Data Transmit through Host Computer. I am Receiving Strange Data Through Serial Port. The receiving string is the picture, please help me to get the result? is there any solution ?
Thu Sep 19 2019Reply from ableh
how can you communicate with the machine.
can you give me an example code how to send it?
Tue Jan 30 2024Reply from Bernabas
