Error 6202 message
Have you checked the service manual?
Advanced Biomedical may be able to help you.
email me: mandy@medwrench.com
Connect with MedWrench:
Hi Don,
Good evening.
to your question
The service manual located here:
https://www.medwrench.com/documents/view/12374/agfa-cr-30-x-service-manual-pdf
Does have a section on troubleshooting. It is section 3.4
I see in that section there are quite a few error codes around non-scanning. Have a look at it.
These digitizing machines are pretty cool. But, I've worked on a lot of them. There are a lot of electronics inside these machines. More than most.
Not to mention the software.
There are other things to consider to get this digitizer to keep on ticking.
1. Contact a repairman that specializes in medical equipment.
2. try to fix it yourself, by buying the parts and fixing the machine.
3. buy a used digitizer - This option is sort of new in the world of medical equipment. It was only 5-6 years ago when this became a serious option. The equipment can usually be purchased from one of the many used medical equipment suppliers online. However, there are only a few places to put the sale into an auction format to pick up some really good deals. One is Mazree at https://www.mazree.com/smart-auctions
4. the last option is to buy new through the normal supplier. This is last because it is the most expensive. But doable, depending upon your hospital purchasing budget.
