Fri Oct 04 2019
Error message after 10 minutes
First time using machine. On for an hour and now doesn't work. Says "System error-control panel. Xrays are disabled. Turn the system off wait 5 seconds and then restart the system. If this message persist call for service." I can turn off for 10 minutes and restart, it will work for 5 minutes, then error message again. Fans run, nothing appears hot, i opened back and ran large fan into case, and did not help.
Tue Oct 08 2019Reply from Minicarm.com
Minicarm.com
Hi Doc,
Does the unit image when it is on and working?
Joshua Bacon
Vice President
PH: 1 (800) 643-2998
www.minicarm.com
