Hello, I have a cart that will not print a Pediatric 12 lead. It will not print after the EKG is performed, or from the File Manager. There is no response/message at all when the Print button is pressed. It will print ADULT EKG's with no issues. Any suggestions?
Thu Oct 10 2019
Won't print Pediatric EKG
Fri Oct 11 2019Reply from MedWrench Mandy
Southeastern Biomedical may be able to help you.
email me: mandy@medwrench.com
Connect with MedWrench:
Fri Oct 11 2019Reply from S. Rooks
Hello Chris S,
I might suggest looking at your unit's pediatric ECG reports found in the system setup / ECG... It may be as simple as changing the reports from 0 to 1+. Use your MAC 5500/HD operators manual for reference. If you do not have one, try this link to locate and download it. https://customer-doc.cloud.gehealthcare.com/#/cdp/dashboard
S. Rooks, BMET
Southeastern Biomedical Associates Inc.
1-888-310-7322
Biomedical Equipment Technician with Southeastern Biomedical 1-888-310-7322
