No video signal in the monitor. Also there is no signal going to the printer.
What might be the problem. Power supply excluded. Already checked.
Fri Oct 18 2019
No video signal in the monitor. Also there is no signal going to the printer. What might be the problem. Power supply excluded. Already checked.
Tue Oct 22 2019Reply from Chris-CBET
no power or no video? no video i'd check the cable first, then possbily the video card. if there's nothing on your display how are you sending a command to your printer? printer could also be a cable, but if you're having 2 issues with 2 separate devies, the common demoninator would be a likely cause.
did any event occur leading to this issue? crash, fall, liquid spill, sw/hw change, etc?
