Problem restoring user settings
RE: Defibrillator Report Post
Have you checked any of the manuals?
One of these companies may be able to help:
email me: mandy@medwrench.com
Connect with MedWrench:
This device will need re-dux kit up-grade. The kit comes with new system board, printer, and power supply.
joey
Edge Biomedical
I've seen the coin cell installed incorrectly and the positive contacts were on the negative side causing this issue.
We can help with this issue at ReNew BioMedical. Please call 844-425-0987 and ask for Neil
Also wanted to add that the error codes will always appear after replacing the coin cell.
you have to clear the codes, clear the memory and power on your unit twice typically before the service light goes away.
seems as if you've done this as you mentioned all the time.
only Stryker has the software.
we can offer trade in credits and put you in a recertified device for less than a software upgrade.
844-425-0987
