Error Message DFE10-62
Run Time Error Code Example: EDEC4 0001
The first character of the code identifies the subsystem. In this example,
E identifies the Scanner subsystem.
K = Keyprocessor
E = Scanner
D = Scan Converter
The second character of the code identifies the type of failure. In this example, D
identifies that the error is recoverable.
D = Recoverable
E = Conditional
F = Non-recoverable
The next three characters identify the error code. Also, if a second set of four characters
appear after the error code, it becomes part of the error code. In this example, EC4 0001
identifies the error as “Missing Autocool option.” Use the table that follows to identify the
error code.
So your error is E10
E10 RS232 Communications failure.
