Thu Nov 07 2019
Service Manual and User Manual Required.
I am facing this kinds "Circle Dis Connect or Leak" error message. What should i do?
Thu Nov 07 2019Reply from Amscopolaris
Amscopolaris
hat is the manufacturer and model name?
Thu Nov 07 2019Reply from ATIK HARA
Model: Base850A
Zhong ke base International Medical Technology Co., Ltd.
Amscopolaris
first check the breathing circuit second check the expirium block may be dirty
what is expirium block ? can you send a picture, i replace breathing circuit 4 time, its ok.
Tue Nov 12 2019Reply from Amscopolaris
Amscopolaris
Circle inside,  Diaphragms in the Expirium block
Tue Nov 12 2019Reply from ATIK HARA
Expirium block inside only two pipeline connector, nothing else. And The pipe is well connected.
so what to do?
Wed Nov 13 2019Reply from Amscopolaris
Amscopolaris
check inspiration block, if problem persists, there may be problems with the valves inside the device
