hey guys, when the c-arm of oec 9600 boots up, it stops at 10 boxes. in the manual it says" EEPROM checksum verification complete". so, it has to do with the EEPROM. I'm thinking it could be the battery of the SRAM is dead or maybe the software. what do you guys think ? what you think is the issue?any ideas on how to solve the problem?(also, I'm not near the unit right now)
Thu Dec 05 2019
error code 10 boxes
Thu Dec 05 2019Reply from ceshop
it is possible the SRAM battery to check with the system turned on yu can unlock the battery access door then remove the battery and check it. If it is very low then try to replace it and reboot the system. normally when the SRAM battery fails you get a checksum failure message. 10 square means the checksum passed and the next test is initialize the keyboard, you might want to check the keyboard connectors
Sat Dec 07 2019Reply from C12Guy
Get the system hop and running. Don't shut it down. Remove the SRAM card change out the battery and install the SEAM. Take a few shots. Should reload
Fri Feb 17 2023Reply from OEC For Me
You can leave the card in while up and running. Remove/test battery and replace.
Anyone know what bit rate is the SRAM? 8 bit or 16 bit?
