Table intermittently doesn't drive vertically. Up nor Down
RE: DR Systems Report Post
Sorry don't have an experience with this table in particular; however, from my experience with other cray tables, I used to face up/down movement issues due to a poteniometer that usually hoes faulty. This potenio meter is responsible for the SID measurement. Hope this will help
Thanks Alsayegh. I know there is a string potentiometer inside the table. I'll have to have the tech look at the indicated SID when the issue does happen. BMET-JohnF do not know what that is. I'm not trained on this unit
Hello team.
I have similar problem.
My table does not work and l think the safety circuit is activated.
Could you please help me disable or deactivate the safety circuit
I'm sure if the safety circuit is deactivated the table will work. Please help me deactivate the safety circuit .
Isaacvandyckbentum@gmail.com Thanks
Hello team.
