I looked through the documents to figure out how to flush the brine pump system. However, while I understand the process, I can neither find the brine pump itself nor the outputs menu to check on the status of the brine pump. Any assistance would be appreciated, as I do not have a service manual.
Mon Dec 09 2019
Brine Pump Flush
Tue Dec 10 2019Reply from Ross
As I recall, the brine pump is in the upper left, when viewing the instrument from the back.
Tue Dec 10 2019Reply from VTKaj
I can see the brine pump through the casing on the back. However, I'm not sure what tools I need in order to remove the casing and access the pump.
Additionally, once I am able to access the pump, do I need to do anything else besides follow the instructions for the flushing?
