The C-Arm is showing Error 4 on switching on and from the control Back panel at the GEN & ERROR PROCESSING board the MMPNR Led is illuminated, from the service manual am told to run the MMP tst, how can I run that test in order to get away with that error. because it doesn't operate when any error is still on. Thanks.
Tue Dec 10 2019
Error 4
Tue Dec 10 2019Reply from ceshop
Thu Dec 12 2019Reply from KASAMBULA TONNY
Thu Dec 12 2019Reply from ceshop
Mon Dec 16 2019Reply from KASAMBULA TONNY
Mon Feb 10 2020Reply from brunorafag
Good morning Kasambula,
I have the same problem in C-arm BV29, the image no appers in the monitors and shows erro 4 on the display.
Did you manage to solve this problem ? Can I help me ?
Thank you in adviced!
Wed Nov 11 2020Reply from KASAMBULA TONNY
Good morning Brunorafag,
I have not solved the problem yet, but i donot know if for you you did?
if so how?
Kind regards.
