service manual
Have you checked the available documents?
email me: mandy@medwrench.com
Connect with MedWrench:
all found within the manual
Specifications Patient Weight (maximum) ................................400 lbs (181.4 kgs) Paper Roll (maximum size): ..............................21 in. long x 3.5 in. diameter (53.3 x 8.9 cm) Export models ....................................................19.7 in. long x 4.7 in. diameter (50 cm x 12 cm) Range of Motion .................................................See illustration on this page Dimensions .........................................................See illustration on next page Weight of Table: [230 VAC models only: 230 V transformer adds 14.5 lbs (6.5 kg)] w/ upholstery .....................................................325 lbs (147.4 kg) w/packaging & skid (no upholstery) .................375 lbs (192.7 kg) Weight of Upholstery: w/packaging (shipped separately) .................40 lbs (18.1 kg) Power Cord(s) [115V models have two cords]: ......8 ft. (243.8 cm) long Electrical Rating: ................................................See Compliance Charts Foot Control Voltage: .........................................14 VAC, SELV (Safety Extra Low Voltage) Duplex Receptacle maximum load: .................................................115 VAC, 5A Fuses: ..................................................................Refer to: Section E - Fuses Duty Cycle: Actuator motor run time: ......................................Intermittent Operation (30 seconds ON / 5 minutes off) Receptacle / Drawer Heater / Uph. Htr: ...............Continuous Operation Classifications: ...................................................Class 1, Type B Applied Part, Ordinary Equipment, Intermittent Operation Protection against ingress of fluids: ................IPX0 [Foot Control only: IPX1] Regulatory Compliance: ....................................See Regulatory Compliance Charts Table Speeds (by function): Base......................................................................14 - 26 seconds Back (models w/power back) ...............................15 - 20 seconds
