Power is on. But The unit does not heat or pressurized. The liquid comes out from the chamber.
Wed Dec 11 2019
Not heat
Fri Dec 13 2019Reply from MedWrench Mandy
email me: mandy@medwrench.com
Connect with MedWrench:
Fri Dec 13 2019Reply from Chris-CBET
is medwrench giving up on it's "medwrench is aresource of direct questions...." everytime someone asks for a manual?
Jj erick, when you say the liquid comes out from the chamber. Do you mean the water is leaking out from the door? or water is entering the chamber? Are you sure your door switch is being engaged?
Mon Dec 16 2019Reply from IndyWendy
I would pull the cover off and check the multipurpose switch. Make sure the micro switches are engaging. If they are look at your heating element. Ohm it out and check for voltage.
Wendy Argueta
Edge Biomed
wendy@edgebiomed.com
