Cannot read a valid Probe ID(00) 3d/4d Error
What piece of equipment are you working on?
email me: mandy@medwrench.com
Connect with MedWrench:
Many times this is a probe issue. Manual shows that if probe is ruled out then replace CRS or CPV
Scott Trefny
Avante Ultrasound 1-800-958-9986
Hello, you can reprogramm EEPROM in service mode.
Need dongle or another solutions.
What about cleaning and maintenance of system?
Also important about probe type, if 4D, need check hardware.
With best regards, Roman
Hello, sometimes a plug is disconnected inside the transducer connector. You need to disassemble it and secure the connection.
PROBLEM SOLVED!!!Thanks a lot all for your posts but the problem was in DC-DC Converter. If anyone need help send email
Hello. i have a problem about probe. not correct id. can you help me dc-dc convertor? please.
