have problem with ct Phillips brilliance 16 slice: when I trying turn on the sytem from the key its not start. Gantry is rotate but its not parking and leds on the gantry not turn on.
When i turn on the key i see Errors in viewer:
s_rmc__error_mco
S rms sb fault
S rms mp dth bad param
S rmc dth bad param
S rotor dth bad param
s collision bad dth param
May be its spindle block fault?
Can you help me?
Mon Dec 16 2019
error gantry
Mon Dec 16 2019Reply from biomed_j
you can try and recommision the spindle block, if the spindle block is bad normally there will be oil under the spindle block. Without seeing the whole log thats the best I can tell you.
Thu Jul 23 2020Reply from DrSaj121
