I have a Force 2 that outputs in monopolar cut are fine. Somethimes in monopolar coagulation does not work.
Wed Dec 25 2019
intermittent coagulation
Wed Dec 25 2019Reply from THURMA
Mono polar good coach intermittently bad.
Is this in handswitch activation or foot switch?
Sat Dec 28 2019Reply from Walin
Sun Dec 29 2019Reply from Chris-CBET
Thu Jan 02 2020Reply from Walin
Thu Jan 16 2020Reply from Rmro
Tue Jan 26 2021Reply from THURMA
Is the problem in both handswitch ports?
If so it would be that clear relay on RF board.
If it's specific to a mono 1 or mono2 port then it's probably one of the big black relays on interface board.
Also when you say intermittent does that mean it doesn't activate or no coag output?
