Cant read error logs PLEASE HELP!
One of these companies may be able to help you:
email me: mandy@medwrench.com
Connect with MedWrench:
I am very greatful for all assistance received on this issue and the information obtained on prior threads here on medwrench. If the issue is solved offline, I will make sure to come back and do a briefing on the outcome! Count on it!
Hello , did you try to replace the main power suppy , since the voltage signal coming from the power supply could be faulty , which is causing the internal errors , if a technician can provide you with a demo power supply u can try
Ahmed Shawky
Ultrasound Field Service Engineer
bambav.medical@gmail.com
Bambav Medical
