Thu Jan 09 2020
Quinton ett software problem
Hello friends, i have a problem in Quinton ett software (Q-stress software version 3.51). when everything ready and start the patient ,during this time system software hung. i was reload the system software for this problem, but system two days working fine and still have same the above problem. kindly guide me
   RE: Treadmill Report Post
Fri Jan 10 2020Reply from MedWrench Mandy
MedWrench Mandy
email me: mandy@medwrench.com
Connect with MedWrench:
Facebook
Twitter
LinkedIN
Tue Jan 14 2020Reply from Connect Wright
Check Atlantis DB 1,2 & 3 if any are above 75% you will need to clean DB.
service@connectwright.com
