Hp Sonos 5500 image problem.
Hello:
No failures related. Battery needs to be replaced in order to eliminate battery error. Battery is a 3.7v AA lithium rechargable located in processor board.
Greyish image usually comes from damage monitor or, consider that this SONOS 5500 system has at least 10 years out of manufacture. Try with another RGB monitor or connect the same monitor to OUT RGB ports and see if there is a difference. Suggestions for troubleshooting. I hope this help.
Dear thanks for reply . I have ordered for the battery . Already changed with a fit monitor, RGB cable to monitor changed. All boards from kep processor section changed and checked but still distorted. Can it be due to NTSC /PAL Mismatch ? Should I changed setting on clock board DSCC board for NTSC AND PAL ? Could it be due to this ? Or should I attach an external LED for sorting it out
Distored or greyish? Be sure your NTSC/PAL settings are right, image distrosion could come from NTSC/PAL mismatch.I don´t remember if there is a part number for NTSC system and another one for PAL system. Be sure you got the right part number
