freezes while downloading data
in the past i have used acronis boot to copy the files over or removed the drive and used USB adapters connected it to my PC thn copied the folders to a backup drive. it is possible the issue you are having is the system hard drive is so full that when you try to copy there is not enough space on the systems drive to write the temporary file to send to the backup media.
Thank you for the answer. Are there any instructions to removing the hard drive from X8 or is it straightforward? I have literally no experience in this.
Removing the HDD is straighforward.
Remove the rear covers; remove the large metal cover.
You will see the HDD mounted to the PC hardware.
Accessing the image database will be problematic though.
I've found that batch exporting is the only successful way to capture patient data.
Attempting to export the entire database, will only give you the result you've described.
