Sat Jan 18 2020
Wisp - permanently updating the Ethernet IP address
Greetings, The copy of windows embedded that is installed on our Ge oec 9900 wisps Ethernet port currently has a manually configured IP address. I am attempting to modify the WiSP Ethernet IP address. Using the windows control panel, I can successfully modify the WiSP Ethernet static IP address. Unfortunately, when the WiSP is restarted, the Ethernet IP address returns to originally configured static IP address. Please detail how to permanently update the WiSP Ethernet IP address. Thank you!
Sat Jan 18 2020Reply from Arthur
Arthur
do you have the WISP service manual?
Sat Jan 18 2020Reply from Pacsadmin530
No, we do not. Email address is brmurray@ucdavis.edu. Thank you!
Tue Mar 02 2021Reply from CCastonguay72
Hello, may I get the WISP service manual as well please.  Chris@xlcon.com
Thank you!
Wed Mar 31 2021Reply from NoahBec
Could I get that as well? Thanks! noahbechtel@gmail.com
