We have proform 590t treadmill that sits in a cold room, so now when we go to start the walking belt the display wont boot up properly. The display just rotates through different setups not allowing belt to start. In warmer temperatures it starts up fine. Any ideas on what might cause this? Thanks
Thu Jan 23 2020
display not working correctly
Wed Jan 29 2020Reply from sergiol
You have a bad contact or cold solder joint. Disassembly it and check the PCB, reset all the connectors.
