I have problems with a Microplate Reader model Stat Fax 2100, this does not save the information, when you turn it off and on again it has restart the date and the data of the results disappears of the memory.
What can you recommend to fix this fault?
Sun Jan 26 2020
Memory Problem
Mon Jan 27 2020Reply from Paul Moyer
Mon Feb 03 2020Reply from acastro06
Thank you for your answer.
I have a question, In which part the instrument is located that battery?
Mon Aug 03 2020Reply from dasanlo
Tue Oct 20 2020Reply from acastro06
Sat Oct 24 2020Reply from Varunbalu7627
